March 5, 200125 yr Has any one used this as it is supposed to make the water more efficient at collecting heat and as such reduces the radiator temp.
March 5, 200125 yr Do you have a cooling problem? If not then don't bother with any of these products. I put NEO keep cool in my previous Z and two weeks later the heater core started to leak. £650 later, I wouldn't recommed it! These products work by removing scale and build-up from the cooling system so that heat escapes more easily. Steve
March 5, 200125 yr No I don't have a cooling problem, but I found a reference to this product while wandering around the web and just wondered.
March 5, 200125 yr oh the core oh the core and the rad over 3/4 of us must now have had to replace these two items of despair i think
March 6, 200125 yr It's working, without any side effects. Quite required when on a race track, with ext temp in the 40°C (like...in Zandwoort last year, for example) Zee you Henri
March 8, 200125 yr Henri, Have you noticed a specific drop in your coolant temperarure since you have used this product? My techtom shows a normal coolant temperature of 82 degrees and a max of 85 degrees. This is with using a synthetic coolant. The reason I tried it before was because I was always running in the late 90's / early 100's degrees on my previous Z. Steve
