Electric Cooling Fan
Ok Well after i blew out my 4th water pump i desided to take some stress off of it by installing a electric cooling fan, the only problem is the one i used dosent keep the car cool so dose any one know of a good fan to use? one guy sugested a Flex a lite Model 210 but i think he was running it in a z31 and i dont know if it will fit in a z32 i havent goten to run my z in allmost 2 months b/c of this problem id like to get her up and running b4 the summers over.
1990 n/a
Markzx would recommend a pacet fan or two, apparently they are the dogs *****cks of electric fans.
Holy hell i can get a 16" that pushes 2354 cfm holy f$%K thats alot of air
Silly question but you wired it so it is sucking into the bay rather than blowing right? I just ask cause blowing hot air forward when the car is moving will restrict the flow on the rad, sucking back is where it should be into the bay and out underneath.
uhhh the fan blows in the direction of the engine if thats what you mean
Are you racing the car as I have never heard of a normal zed, blowing 4 water pumps?
