PAS pump leak
Reversed the car out of the garage this morning, HICAS light lit up & found large puddle of PAS fluid on the floor. Having jacked the car up to see where it was leaking from it appears to be coming from the back of the pulley/drive shaft so I'm assuming it's the drive shaft O-ring.
Found Doobs too's removal guide under FAQ's so will make a start this afternoon.
Anyone have any other advice on doing this? Any other seals I should be replacing while I've got the pump off? Where should I look to get new parts from?
Many thanks in advance.
Les
Found out the front drive shaft bearing was mangled, new pump....?
second had one would be cheaper, although hoses leak from time2time the units themselfs are pretty robusts, the seals and o rings are replacable but sounds to me like you need a new one?iv stripped down a PS pump, but not sure parts are on the market unless you use an aftermarket centre, normally pick up a used PS pump for 30-£50 anyhow
