Should this be loose.
The MOT is due so i was just checking around the car and found a boot on the steering rack split.I cut it off ready for the replacement only to find a large thick washer type thing on the shaft which was loose :confused: Should this be loose or has it sheard off something. :(
It's the ring in the middle of the picture.
its a "steering gear spacer" and it comes with a rubber side wich must be fitted to the lock-plate by pushing up to it,looks like your rubber has come off it. the boot then pushes up to it and is held by a "boot band" hth ;)
Cheers Znut :duffer: :D .Is it much of a job to change ?I presume Mr f at mjp will have one ?
no but mark were the old one comes off to and after fitting you,ll have to get the car tracked,the rubber side faces the rack
indeed just mark where thread is before unscrewing tie rod, then refit to same mark.
Cheers lads.Have a drink on me :duffer: :duffer:
ile have a b/c get the young lad a lemonade he,s from the south :tongue:
One shandy for Greg coming up, after i've asked his mam :D
ROFLMFAO cheers lads, babycham will do!
I presume it's with a cherry :tongue:
and an umbrella FFS get with the program! :rofl: :D
