will Manual engine fit to an auto as strait swop
yes ..but i bit more than a straight swap!!!
loom/ecu !!!
andyduff is back on monday,, he's the man to ask !!!...
he's at the British GP...having a great time ... :D
wozza ...
Yes it will, Spigot bearing in the crank will want changing, and being a manual, the turbos will not spool up as quick as an auto. But its hardly noticeable!
Thanks for the reply, probably better explain myself a little more;
My car is a J spec auto, the engine has had it, I have the chance of an engine from a J spec manual from Stenorth that has head gasket failure, i wont be changing the box as I am sad and like autos!!
Hence the question as to wether it would be a strait swop over?
Dont forget bud....if your putting a manual engine with an auto box, make sure you've removed the manual spigot bearing and fitted the auto one to the end of the crank :D
Also you will need to fit the auto flywheel and starter too.
The driveplate for the auto, and starter will be on the other engine/car.
