- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
Hi guys,
we are having a few issues with a 1990 TT.
We did alot of research in here and TT.net but still have some questions, and maybe someone can link the problems together etc...
MODS:
JWT Stage 3 ECU
JWT Single POP intake
Blitz SBC ID3 boost controller
RPS clutch & Flywheel
The car is running the stock exhaust with gutted cats. (Waiting for a SpecialtyZ system; downpipes and cat back.)
We tested it with Conzult, everything was fine. Power balance test was ok, and everything else seems normal.
SBC PROBLEMS:
First we installed the Blitz ID-3 using this guide from TT.net:
http://twinturbo.net/net/viewmsg.aspx?forum=general&msg_id=995129&forum=technical&dtSearch=0
It says to mount the boost solenoid to the firewall behind the battery, thats what we did. Everything has been hooked up properly and we also installed the power meter ID and hooked it up to the speed wire Pin #53 from the ecu harness. We are experiencing unusual boost spikes. I talked to many people and their settings for 15 LBS are around GAIN: 10-15 and a SET: ~40. However when we have our SET to 35 and whatever GAIN we use it spikes to 15.0 - 15.5. Only when the GAIN is 0 that we dont get any boost spikes at all. These seems like really low numbers. (SET 35 GAIN 0). We set the limiter to 14 and because of the spike while testing it went all the way to 15.6.
What is the max boost the stock engine, stock turbo, stock injectors can take for a similar setup. We run on Octane 94.
Not sure what could be the problem, Vacuum leaks? Location of the Blitz solenoid module? Where is the best place to mount it? Also do the vacuums need the same exact exact length between the solenoid and each waste gate? Could the exhaust restrict the car too much?
We used the option B from that guide and left the stock boost solenoid in place and we just disconnected them.
EGR PROBLEM
Once we got the SBC ID 3 installed, we took it for a spin. After around 30-40 mins of driving the check engine light turns showing a EGR System code 32. We double checked all the hoses. Everything seems ok. Not sure what can be the problem. The car is a CALI and use a JWT cali ecu as well. I have been told I could delete the EGR by using a Fed ecu and disconnecting the EGT sensor (They are only on Cal cars). That way the check engine light would dissapear. We dont have any emission test here in quebec so deleting the EGR should not be a problem.
RADIATOR:
We also had the Radiator. The core was perfect, but the sides are in plastic and its leaking from where they connect. we tried tighting up the metal clamp and adding sealer but its still leaking. We ordered an AMS radiator with a Z1 solid lower hose. This should fix this problem.
LEAKS:
We also had a turbo line and the rear main seal leaking oil. We fixed all that while installing the new RPS clutch and flywheel.
Now we have another leak, Its from the passenger side, at the back of the engine. We can hear drops falling then pshhhhhh. I suspect the heater hoses maybe. Another strange thing, when accelerating there is a small rattle that seems to come from behind the dash on the passenger side. Its not very loud but I can hear it well when driving. It started to do that after we installed the SBC I believe. Could it be the pressure in the vacuum that come in from the passenger side fender hole? When detonation happen is it a small noise or its very loud? Just still trying to figure out what could be the problem here.
SUSPENSION:
When going over 200 KM/hour and hitting a small bump the rear want to fishtail. Its scary and hard to control. We originally thought the problem could be an alignment. The car is running still on stock suspension. Maybe the problem is the HICAS. Would installing the HICAS remover Stillen kit fix this problem? What else could cause this?
This Z is hard to work on, there is not much space under the hood!
:cuss:
