Help Setting Up Power Boost Control
I've got this Power Enterprise .Power -Hybrid Boost Control and need help and advice to set it up.Diagram would be invaluable!! as all it came with was in Japanese :D
Here's the photo!
Good luck! LOL :rofl:
Never seen one of those before in all my years on here :confused:
Might just be 12v to the red wires, ignition/lights switched 12v to the yellow for dial illumination and black to earth.
Vacuum line from balance bar to the boost sensor.
Boost solenoid needs to be T'd in to the 2 wastegate lines and there's a write up on fitting the Blitz controller here somewhere which shows the pipework you need.
Cheers Chris,I will find the Blitz fitting diagram
Rich
I assume you got the turbos then!...what did you go for?
Dave
Hi Dave, Yes;found Power Enterprise PE1420 turbos,Dupree wastegates and testpipes.Apparently the turbos have only done 5000 miles(fingers crossed)and this with chipped ECU and the boost control should take it up to 460rwhp..ahh....Oh,I also bought an hp street clutch from Smithy and some rear shocks ..so all that remains is to put it all together . Hope this bit goes smoothly as it is getting quite expensive :D
Here's the photo!
Still looking around for a diagram to help me plumb this boost controller in.....Anyone ?
