is my turbo ****ed?
the car makes a whistling sound when the turbo kicks in, the car still boosts fine and their isnt a lack of power, just suddenly happened this morning
are all the pipes accessable without removing the engine
the pipes at the top look ok
They may look ok but its how they cope under pressure.
is their any tell tale signs if its an acutal turbo or a boost leak
i am defo not loosing any power, when on the motorway doing high speeds i hear the whine alot louder and their a sort of spluttering noise
First of all carry out a boost leak check then go from there!
People sell them on here occasionally
well im gonna make one and get it tested on monday, if its a boost leak, i gather i will hear the air coming out of a pipe?
ive been reading alot of posts and i am undecided whether its a leak or a knackered turbo
the car still seems to boost fine however the aftermarket gauge is quite inconsistent now
one min its boosting to like 10psi the next 6psi
If the gauge is hap-hazard then a boost leak is certainly a possibility.
this is probably gona sound dumb to you guys but how do you do a boost leak test :confused:
