Just bought a 86 Camaro 400 BHP lol
Just bought this from the States for a laugh (expensive one AAAHH)
Im quite excited, just thought i would share that lol :hyper: :hyper: :hyper:
Photos ASAP! I have a soft sport for American Muscle cars...as one of my choices before getting the Z was a Gen 4 Z28 Camaro!
I'd swap the below example for mine with out a moment's hesitation.
So would I Si. Its got a Monaro look about it dont you think?
Yeah i love Yank tanks too, I used to have a Corvette when i was richer, exactly the same as this although i have not got a piccy at work.
sorry i might be way out but when the top gear lads did america did they use a camaro? as i really like it and it looked similiar!!
Yeah similar shape to mine, but i've got a 350ci instead of a 302 he is the list of mods,
Cant wait to drive it (smokey tire's i think)
1986 Z28 HI-PO BEAST
Engine / Rotating Assembly
• 91 350 cubic inch roller block motor 46,xxx miles
• 10/10 ground crankshaft reconditioned / polished
• 10/10 rods sized and polished
• new clevites bearings
• complete felpro gasket set
• new TRW pistons flat top 4 cc relief 9.5to1
Fuel/Air Delivery
• Holley 600 cfm zinc plated electric choke carb
• Holley 10 inch chrome air cleaner assembly
• K&N 10 inch rechargeable air cleaner
• Weiand x-celerator manifold 2000-6500 rpm range
• Bowtie phase II iron heads ported and polished 2.02int 1.60exh valves with bowl blending seat size 1.55 outside diameter
Cam/Valve Train
• GM performance parts zz4 cam Duration @ 0.050" 208/221 Valve Lift 474/510,
112 Lobe Center Separation
• Crane cams hydraulic roller rockers.
• Comp cams magnum pushrods 5/16 stock length
• Comp cams valve stem seals umbrella seals
• Comp cams 3/8 screw in studs
• Proform 1.6 full roller rockers 3/8 blue anodized
• GM performance lt4 light weight springs 1.32 od
• GM performance lt4 light weight retainers
• GM performance light weight valve stem locks
• ARP posi locking adjustable rocker arm nuts
Drive train
• T-5 Borg Warner world class built with forged internals 5 speed
• Gm quick throw shifter
• Chevy 10 bolt 28 spline axles 3.23 gearing open carrier
• Clutch masters stage 1 HD clutch
• Clutch masters HD pressure plate.
Suspension
• 36mm front sway bar iroc
• full polyurethane kit
• Eibach pro kit lowering 1in
• Gabriel front shocks
• Gabriel rear air lift shocks rear
• Bmr pan hard rod
• Lakewood lower control arms
Exhaust
• Hooker competition headers
• ARP exhaust bolts 3/8 1inch
• Percy’s dead soft aluminum header gaskets
TRUE DUAL 2.5IN EXHAUST TO THE BACK
Ignition
• Mallory dual point distributor
• Mallory distributor cap
• Mallory rotor
• Mallory dual point 6000+ rpm floating points
• Accel super coil 12 volt 50,000 output
• Accel ballast resistor
• Accel 8mm double silicone spark plug race wires
Chrome
• Holley aluminum polished finned valve covers
• Holley aluminum chrome air cleaner
• 18 inch black flex fan with aluminum blades
• Chrome water outlet housing
• Chrome oil fill cap
• Chrome power steering cap
• Chrome alternator brackets
• Chrome valve cover hold downs
• Chrome t-handle valve screws
• Chrome wire looms
• Chrome distributor hold down
• Chrome dual throttle springs
• Chrome valve cover breather
• Chrome 3.5 inch exhaust tips
• Chrome hood pins
• Chrome fuel filter Mr. Gasket
Clarkson's one was a Gen 3 IrocZ
They look pretty cool. Prefered the Cabrio though, like this. Although prefer the 17" Iroc rims compared to these aftermarket numbers.
These are the 17" Iroc wheels that would look better than the above. Rare as hen's teeth too.
Arrrrrrrrr, found it. This is the one fitted with the above rims. This was the car that got me into the Iroc fan scene. This is simply stunning...
Lovely looking car.
I think the 'baddie' in Whetus' song "Teenage Dirtbag" drove an Iroc. :dance:
now what the point of a 400+ car that cant stop or go round bends.
With upgraded brakes and suspension. You could say the same about the Z. Stock Z brakes aren't up to much and nor is the 17 year old suspension. I've driven a Camaro with uprated springs and shocks and it handled very very well.
Wouldn't have thought you'd be into those Si? Doesn't seem like your usual taste. I don't know anything about the Camaro (the ones above look nice by the way), but I know that anything but the Z06 vettes can't go around a track for toffee with their stone age truck suspensions and subtle as a mallet engineering. I'm yet to see a big yank car that can do corners. Excuse my ignorance if I'm completely wrong! I don't consider them comparable to the Zed, which although certainly not a track car is pretty nimble for its size and weight GT status.
That one you've bought James F looks pretty mental though, gonna be fun no doubt about that.
that is just stunning :bow:
They are a different kind of car to the Z. It's not something I'd use in the same way as the Z. I don't even drive the Z that hard. I love the looks and noise of the old LT1s. Really raw and can be tuned for very little. Pretty much bullet proof engine too.
As you say my old corvette had the Z06 suspension upgrade but apart from that yes they generally dont go round corners. But for strait line mental fun they cant be beaten lol
The only Camaro I would consider owning, the 1969 SS or RS. Beautiful car and made of pure American steel!
Have got that as a donor then James? LOL!-I take it the 'swap' is out the window then? :D
Great car mate, loadsa fun with that !! :hyper:
Had several Camaros in my time ! :o
Wont be long till you are doing this kinda irresponsible behaviour !! :D
Alan.........
.Black 85.
Red 86.
Orange 78.
Alan............ :D
nice car mate. i've driven a couple of 1960's cameros and they were awesome.
Different car?? but reminds me of the smokey and the bandit films :D I always wanted one of those cars when I was younger. I got the T-tops eventually ! I miss them now though. :nelson:
