tub psi pick up rate?
hi guys,
i have recently set-up my avcr apexi controller with a rolling road guy! the car is max boosting at the desired 16psi and with all my other mods should be around 450+ at the fly,
thing is im not sure the car seems as quick as it should be low down, seems to take a while to get to max boost! admittadly its an auto but in std form i used to get back end out all the time but now cant?
my question is can you adjust the rate at which boost pressure is gained throught the apexi controller??
when set up it was adjusted with change of duty cycle not kg pressure! is this correct?
if not at what setting should i put pressure too b4 adjusting duty cycle??
any help gratefully recieved
regardss steven
My son had a similar thing with his GTR, not that his was slow, but after someone adjusted it, it came on boost much sooner and stronger.
So, although I have no experience of your controller the answer has to be yes. Now all you need is someone to tell you how.
