water temp sender size!
hi, im thinkin of buying one of those water temp senders that fit in the rubber water hose(cant be arsed to faff about drilling and tappin the hard pipe), any ideas what size i need.
many thanks
si
I had a Greddy one in my top hose , it caused alot of problems.
The rubber top hose has a different diameter at each, meaning the pipe tapers, so when you cut a section out to fit the alloy adapter it,s a nice fit one end but very loose the other so you really have to over tighten the jubilee clip to get a good seal , this in turn caused a failure of the rubber pipe cos the jubilee cut into it . :smash: :smash:
Luckily for me i was near the Z Centre at the time and Luke helped me out :bow: :bow:
Had this done instead , only cost a few quid and looks neater as well :hyper:
