boost leak??
been told i may have a boost leak or vacuum leak, how do i find the leak??? or do i just change all the boost hoses?? like i have said on the previous thread the needle is just below the first line (on the left handside) on the gauge
Sorry!
Go around and tighten all your jubilee clips first.
The four main fat hoses
The two on either side that enter the turbo
Check under the arch splashguards at the intercooler ones if you can
Then check all the vacuum pipes for splits etc. Spray some wd40 to help find leaks.
Get a boost leak detector and put it in place of the air filter and pump up your system up, just not too much!
lol did you just have a boost and a leak handy just for times like this??
thanks mate.
