Horn help!!!
Is the horn button on a zed positive or negative?
When pressed the horn button goes to Earth,is that what you mean? ;)
dont know!!! Ive got a set of twin air horns coz my origional one sounded like it came from a noddy car!, Theres a relay with the kit and it shows 2 different methods of wiring one for a 'horn button connected to positive' and the other...'horn button connected to negative' . The instructions say....'Origional horn circuit may be positive activated, or ground activated. Determine your circuit by connecting a test lamp lead to ground and the other lead to first 1 and then the other origional horn wires. If one of the wires carries current (ie the lamp lights up)you have grounded horn button, if not you have positive.
I dont have a tester or for that matter a battery or even a steering column at the mo!!
Shouldn't worry about it at the mo' then!! LOL! :D
