anti lock brake light and turbo gauge
Hi 32z 1990 twin turbo I have the anti lock brake light on all the time,I removed fuse to see if it was the fault but the light stays on without fuse,is there another fuse apart from on in box under hood,also turbo gauge(original fit) does not move it is minus hard to the left I have checked vacuum pipe which is intact,any ideas as I am new to 300zx and only bought it 3 weeks ago so struggling to find anyone to help with problems thanks bavis
Thanks for replying,let me know where you are and I will come and see you,to answer your question it is a 1990 300zx Twin Turbo 2+2 Black Thanks Bavis :hyper: :hyper:
Sounds like a short on the back of the clocks if the boost guage is hard to the left.... Fuse would cause the guage to be central
Sorry Andy but the picture of my gauges out of the car shows the boost gauge hard to the left.
There are fuses in the drivers footwell on the right. Do a search and you should be able to find a picture showing what is what.
Found the diag. It is here http://www.aus300zx.com/tech/fuses.htm
Darrell
