Serious Starting Problem Need Major Help
- Replies 42
- Views 2.2k
- Created
- Last Reply
clive01 13 posts
nzniggles 6 posts
fraser_gtti 4 posts
Jack 3 posts
BIG PROBLEMS!
To give background i had a long journey in the car last night from london to derby and back. It was very wet if that makes a difference but when i went back to the car this lunchtime, a good 11 hours since the journey, it didnt start.
I turn the key and it gives a couple of normal turning over chugs and then CLUNK. sort of similar to when you start the car in gear but different slightly and the car wasnt in gear.
Tried again. CLUNK. Tried again. CLUNK.
Went to look under the bonnet and noticed that where i hadnt secured one side of the upper fan shroud it had obviously come into contact with the viscous fan and it had destroyed a small section and also worn the tops of the fan blades down an amount. The shroud has not been secured on one side for a few weeks and this hadnt happened previuosly even with long journeys. Perhaps extra forces from water heavy air had caused it or higher speeds.
Thought a shard of plastic might have been caught in one of the belts and the front so had a feel around but couldnt tell much.
Tried to start again and there was a CLACKING noise similar to when you put football cards in the spokes of your push bike as a kid.
Had another feel around and started it again. This time there was just a WUURRR from what must be the starter motor running freely. I heard fuel pump knocking too. tried again and it was just the free running WUURRING which seemed to be coming from the bottom-back of the engine.
I understand that keep trying to start it with a problem hasnt help but can you help me piece this together to figure out what is up????
