HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate expensive car parts not far from the object we are trying to hit.
STANLEY KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on boxes containing Samco pipes.
PLIERS: Used to round off bolt heads.
MOLE-GRIPS: Used to round off bolt heads & nuts
BENCH DRILL : A tall upright machine useful for suddenly snatching flat metal bar out of your hands so that it smacks you in the gob.
WIRE WHEEL: Cleans off engine bits and then throws them somewhere under the workbench with the speed of light never to be seen again.
HYDRAULIC FLOOR JACK: Used for lowering your Zed to the ground after you have installed a set of Nismo lowered road springs, trapping the jack firmly under the front spoiler
PHONE: Tool for calling your neighbour to see if he has another hydraulic floor jack.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool that snaps off in bolt holes and is ten times harder than any known drill bit.
TWO-TON HYDRAULIC ENGINE HOIST: A handy tool for testing the tensile strength of the hydraulic clutch lines you have forgotten to disconnect.
LEAD LAMP: The mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, "the sunshine vitamin," which is not otherwise found under cars at night. Health benefits aside, its main purpose is to consume 60-watt light bulbs at a pace quicker than you can replace them.
PHILLIPS SCREWDRIVER: Used to round off
Phillips screw heads.
FLAT BLADE SCREWDRIVER: Used to open the slot on tight screws to a width greater than the width of the screwdriver.
Little definition list for ya all...Jeff TT
300 zx Automotive Tools
