Ecu Wont Switch Off!!
Hi Guys Can Anyone Help Me, My Z Had A Starting Prob Turne Out To Be The Earth Trigger From Ecu Not Sending Signal To Ign Coil Relay, But It Sorted It Self Out, Now The When I Take The Key Out Of Ingition Car Switches Off, But My Apexi Units And Ecu Stay On, But B4 They Use To Switch Off, Also My Engin Management Light Does Not Come On The Dash Any More!! Also I Need To Floor The Accelarator Pedle To Get Car Started When It Does Its Rough Takes A Few Min To Smooth Out Any Ideas On That? Any Help Would Be Appreciated.
HI I HAVE DISCONNECTED THEM BUT STILL SAME PROB, DO YOU KNOW WHERE THE ECU IS POWERED FROM? IS IT DIRECT FROM IGNITION OR FROM A RELAY I WAS THINKINH STICKING RELAY AS WHEN I TAKE BATTRY OFF OR THE IGNITION RELAYS AND PUT THEM BACK IN THE ECU AND APEXI UNIT GO OFF!! STRANGE
remove your apexi units, reset ecu and test car.. if alls well start again. Sounds like faulty wiring. Muffin.
