Engine Assembly time.
Managed to get the heads back on, all the lifters and cams torqued down again, then fitted the cam gears and went to do the belt.
Not as easy as i remember it a few years ago so had dificulty getting the marks to line up with the crank pulley at the bottom.
I'm guessing the sprocket is slightly out so i'll try again tomorrow, but need to find some clamps to keep the top done.
By
JaiKai ·
Hey guys.
I've just put a deposit down a on 300, uk spec twin turbo manual. But in the advert, the guy said it has a two stage boost button.
I'm just wondering if anyone in here knows wot it does? I'm assuming that it either alters the boost pressure or injects something to give more boost?
Any help would be appreciated
Mikey
