May 2, 200719 yr I'v just changed the ptu, and the dam thing still aint running right. Starts ok then sits at idle and then engine just dies... Ignition lights on.. Starts again... Runs on idle.. Then dies again. PCV valves? Or just a service? Both... :wack:
May 2, 200719 yr I'v just changed the ptu, and the dam thing still aint running right. Starts ok then sits at idle and then engine just dies... Ignition lights on.. Starts again... Runs on idle.. Then dies again. PCV valves? Or just a service? Both... :wack: Have you checked your coil packs ?? could be the MAF also do a search on coil pack checking and see if you can borrow a MAF from some one ..good luck mate ( what error codes are you getting up from the ecu?? ) Steve
May 2, 200719 yr Author Have you checked your coil packs ?? could be the MAF also do a search on coil pack checking and see if you can borrow a MAF from some one ..good luck mate ( what error codes are you getting up from the ecu?? ) Steve Hi mate, Ok... I'm a bit of a novice me. So whats a MAF? Where do i check the ecu error codes? What am i looking for? Cheers m8. Pete
PCV valves?
Or just a service?
Both... :wack:
