Injector connector removal
Specifically the back 2 by the balance bar - I've got the other 4 off and I want to replace or at least clean these last 2 up as they have poor connections which I think may be causing a misfire.....
does anyone have any tips on how to do them as the metal clip is facing away from me and I cant easily pry the clip out....
also - I've come across this website that looks like they stock injector connectors - can anyone verify from the pictures if they are a match or will fit with any modifications as they are very well priced.....
http://www.vehicle-wiring-products.co.uk/VWPweb2000/connectors/photo/4145.jpg
or if this one fits as its a bit larger but has an easy spring clip removal on it
http://www.vehicle-wiring-products.co.uk/VWPweb2000/connectors/photo/192147.jpg
any help is appreciated.
Ta!
Yeah, but they cost a fortune and if these are the same pattern they are infinately cheaper.
Take the balance bar off its a lot easier to get to the rear 2, they should easily come off if you get a flat skrew driver under them.
Mike sells his connectors for about £25 for 3 which includes wire already fixed to the connector so can be soldered strait into the loom
Yeah, I found that tip and it worked - didnt need to remove the bar so a bi tless hassle - yep - no way I'm paying £25 for 3 pieces of plastic when I can build all 6 for about £15-17 quid.
