I am fitting 3 gauges to a pillar pod and was wondering rather than making one engine coolant, plumb it into the auto box. Anyone done this?
Cheers John Crisp
Not done it but its a good idea - If you fit an auto box cooler then it will be easier to fit one at that point where the line goes into the cooler box.
Its not a bad idea as an additional gauge...however aftermarket Engine coolant temp is by far the most important gauge!
I've seen so many headgasket failures after overheating because the stock gauge did not warn the driver
Bilky its a uk car so the cooler isnt an afterfit.
Good point David it might be an idea to have 2 coolant gauges, one for engine and one for gearbox. I was just thinking of trying to plumb it into the gearbox just as an additional gauge. I need to get the car into work over a pit and investigate.
Cheers guys John
Ivi fitted a defi gauge for the auto box. ive got a T peice before the oil cooler with the sensor mounted in it.
i fitted autometer c2 temp gauge for my auto box oil, i removed sump pan and had union for sendor welded to it! works a treat!
