aircon fix
anyone who cant get cabin vent or footwell to blow check this.....i've been having trouble these last few weeks getting the cabin and foot vents to blow i tried every kind of setting in all weathers but the air stream always went up the windscreen i was beginnin to think a motor was broken :(....so did a read of the diagnostic and adjustment...and there were no errors...however one bit mentioned when you disconnect your battery you can lose your settings or rather they revert to default...so after a trial and error i found the setting which adjusts the difference between top and bottom cabin temp....tried a couple and hey presto warm feet again :)
How to
ignition on....
on the aircon pod press auto and off together for 5 seconds...goes into adjustment mode....
press auto twice....the display should say 40 at the top...then use the low fan speed button to lessen the bottom value to -5 (well that is the one which worked for me)
press off and your done...might have to go for a 5 min drive so it can sense the temp but its worked 100% for me ever since
chris
No posts to show
