I know what I am doing as far as installing the unit goes apart from where is the best place to get the RPM feed from? ECU I presume, but which wire?
Now comes the fun bit, setting it up? Anyone got any hints & tips? Ive read there is an AUTO setup mode. Is this worth trying?
Any info would be great!
Pete
ECU pin seven is the tacho wire and is yellow with red spots/stripes.
It is located four wires to the left of the centre bolt on the top row (viewing the loom with the bolt section raised upward)
Note: this refers to looking at the ECU with harness connected from the harness/wiring side - ensure you note the raised section around the bolt- and correspond to the correct ECU wire double checking the colour is correct.
You don't need to disconnect the ECU loom from the ECU, just remove the white plastic protector.
Cheers guys.
Does anyone know if the learning mode is worth trying on a Z? Currently got a profec B and when i set that up it was more a trial and error method.
Also for those that have one of these, where have you located the screen and remote?
most people have stuck or screwed the screen to the top of the dash, and the keypad some have used the black bracket to attach to the dash, others have them sitting loose in an empty DIN tray or somewhere.
I was under the impression that the auto/learning mode didn't work with twin turbos - could be wrong though ....
This is what i need to know :)
I'll give you a hand setting it up bud :)
Cheers andy. Will give ya a shout when ive fitted it. should be this weekend hopefully. Ive also got some stuff that stevemochan has bought for his car to pass onto you too :)
ECU connections?
Cheers graham. I'll be ok installing it. most of the stuff is already installed (boost valve is the same as the profec B) and you'll be here anyway to help me solder the wire on the ECU ;)
Cheers guys.
dont bother with the self learning, hit and miss is better, that how i've done 2 now.
Cheers guys.
Dont suppose youve got the fitting instructions for the profec B if so could I borrow them please mate, (in case its important mines a spec2)
http://www.greddy.com/img/PHP/products/pdf/682.pdf
