Cam belt change
Hello all,
I have a H reg tt uk spec and im thinking of a cam belt change as I dont know when it was changed last.
Can anyone tell me how difficult this is to do? is it an engine out job? and what would the price be at a main dealer?
Also if anyone can tell me what problems you would get, if any, by over filling an auto box as mine has a dodgy reverse when cold and when going through the gears hard it goes from 1-2-4-3-4 would this be due to over filling??
Cheers all!!
we can do a full service including belts for £400.
yes if the box is overfilled it wouldn't help with the gearchange tbh
Main dealer prices for same service is about £1000
hth
paul
Thats not a bad price! I thought it would be alot more expensive and I will keep you in mind for sure!!
Just been under car trying to look for a drain plug on auto box but couldent find one, how do I drain some of the oil out?? cheers!
I did mine myself but you should know your car pretty well before you try it. I would take Paul up on that, it's worth having someone who knows the car and it's a good price.
I wasent under there for long a bit of a tight squeeze! Which side is it on?
just had it done , new water pump hoses etc, 715 squid, front of engine off rad off etc
I presume its done without taking the engine out??
Bottom left 19mm socket :)
cheers martin I shall have a look again later, just giving her a wash!
Prolly be worth draining/changing oil while your there, its often overlooked :)
How much oil to fill her up again if I drain the lot?
There isnt always a drain plug for the TT - mine doesnt have one - I siphoned the fluid out of the filler neck using a pump I bought from Demon tweeks.
I couldent see one myself but I wasent under there for long, you could be right?! cheers mate!
