- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
OK - heres the symptoms.....
uneven idle - revs stay around 750rpm but idles rough.
No hesitation
Fuel economy is fine
No loss of power.
Changed fuel filter
cleaned throttle bodies
replaced spark plugs
when removing each injector connector - engine note drops, then picks back up when plugged back in
ditto for the coil packs.
sprayed carb cleaner into idle unit.
none of this has made any difference.
Was going to squirt wd-40 into idle unit in case its got sticky. But I'm out of ideas at the moment
The car runs perfect off idle, its just when it comes back down.
Any ideas welcome.
