Boost-temp-oil Pressure Gauges
hi peeps,.been looking on opie oil site,was looking at there gauges,do i need mechanical or electric,going to puy them in a pillar pod,want boost gauge in psi,oil pressure,temp gauge,oh and what size gauge do i need to fit the pod, cheers garry
I can't help to much but as far as I know, the mechanical/electrical gauges are basically the same, it's just the way that they get their signal, and I would presume that the electrical ones are more accurate
As for the gauge sizes you should take a look at the specs for the A-Pillar pod, it should tell you what size gauge it was designed for
I'm sure someone else will be along soon to give more helpful information
Paul at SWZ performance does some real nice ones (which I have just bought) they come with all the wire and senders. You can also set a high warning sound on them.
cheers peeps,just thought the ones on there were rather cheap,will hav to hav a good search on google. :)
52mm or 60mm, its up to you. Electrical or mechanical. They should all come with the nessesary senders.
Those Gauges supplied by SWZ are great quality and have the spec of gauges costing 3x the price and have been getting fantastic reviews :bow:
Yep i have these as well... any ones related to oil pressure and temp will need to be electrical as they are much better then mechanical and much much easier to fit, although with boost it doesn't mater as i have used both types and both are easy to fit.. hope this helps :)
