ride height!
hi guys!
i have just fitted eibach springs and kyb shocks to my 2+2!
the trouble is a have removed air-con, egr etc etc which makes front end lighter,
and have big stereo boot build which makes rear end heavier!
if i look at tyre to wheel arch clearance the front end sits 1 to 2 cm's highter than rear! is there anything that can be done about this?????
regards steven
you could take it to a 4 wheel alignment shop, they would check pretty much anything you could ask them too, i would also recommend that after changing anything on the suspension.
Something Like This
thats already done mate!
all is within spec,
any one with any ideas please!!
how about cutting off couple of inches of coil spring on front??? he he!
No No!!
You are just having a laugh I know.
One solution is to get a pair of height adjustable coilovers.
I know that makes your current front pair redundant.
Only other way is trial and error on some different lowered front springs.
I have a motor just come in on really low springs at the front which I dont like. possible swap???
