knok sensor
where can i buy 1 from, how much, how hard is it to get & to & fit
also what does it do?
its a piezo coil that detects engine knocks at a certain freqency (detting) and send a signal to ecu to retard ignition and reduce boost, big job to relace as its under the lower plenum
its expensive and a bitch to fit unless you relocate it, bypass it with a 1 Meg ohm resistor like I have ;)
how much & where from, as im going to need this?
fitting is not a problem as my wee mechanic will attempt anything
:dance:
:dance:
the plugs here bud,disconect and put the resistor on the ecu side of it like ive done
ok that sounds cool
where do i get the resistor? that i will need? :rolleyes:
Check for green shit on the connectors first. Have you done an ECU diag and are getting code34 ??
What has propted this post ?????
HAD LOADSAA TROUBLE
CAR WIDNI START
BROKEN WIRING EVERYWHERE
EVERYTHING IS FIXED AND TURNED OUT TO BE BROKEN WIRE AT ECU
SHOWING CODE IGNITION
CAR IS STARTING NOW AND ONLY CODE IS KNOK SENSOR
REPLACED BRAND NEW PTU ASWELL
ALSO WILE IM ON I BOUGHT A MINES ECU
WHATS THIS GONNI DO FOR ME?
YE'S AWWWWW KNOW YER STUFF ON HERE I TELL YI!!
TA MATE
Is yours a TT ?
A mines ECU won't do much on it's own, you'll have to up the boost via boost jets or and EBC te get the most from it if you havn't already done so
HAD LOADSAA TROUBLE
CAR WIDNI START
TA MATE
unless you,ve got reduced boost it might just need the code clearing from an earler fault,safety boost corrects its self on next start untill it detts again anyway
Is yours a TT ?
ITS TT
YEH ITS JUST THE MINES ECU
ALREADY HAS
HKS IND KIT
HKS TURBO HARD PIPES
FULL S/STEEL EXH
S//STEEL DOWNPIPES
LOOKIN TO UP THE TURBOS & INJECTORS
  • 1 month later...
