HELP !! Drivers seat belt won't retract
i had the same problem. i think there's an electrical cable attached to the seat belt. i disconnected it and have not had any problems since.
hth
alex
hth
alex
CheerZ, I've tried that and no effect.
I have wound it in a little by hand and now it's neither coming nor or retracting :confused:
hmmmmmmmmmmmmmmmm. sorry thats all i know. :confused:
Sounds like the inertia return spring has gone on it mate. Best bet is get a secondhand item I am sure someone who is braking will have one going cheap?
Vini
hi budy mine did the same when i took it apart one of the little plastic cogs was in bits i took it out and its been fine ever since
CheerZ
Will have to check it out on the weekend
CheerZ
you will need to take all the doorcard out and its located where the seatbelt returns its a bit fiddly but you should be able to see the mechanism and see if anythings amis ..good luck buddy
Sorted, same problem here :cool:
Just got to put it all back together now :rolleyes:
