The zed is going back on the road tommorow but my indicators don't work all the other lights ie side,main,fog,and even the hazzard lights work i've checked all fuses and even had the stalk out but can't find anything please please please help if you can i;m desperate to drive her.
thanks in advance.
just had another look and when i switch the lights on the warnig light comes on, on the dash but everything works apart from the indicators.
the hazzards are working though i had the tial lights out a while ago so i could tint them but its all plugged back in
Yeh they will but if the switch doesn't return properly it stops the indicators working.
Quite common.
right i'll give it a shot would that make the warning light come on though?
thanks graham it was the hazzard switch and 1 of the side light bulbs are out on the back but i got it sorted now thanks very much for your help i can take her out now.
Remove the hazard switch.
On the plug connect pins 1 and 2 together.
This will eliminate the hazard switch as the problem so you can drive it ;)
cheers ollie got it sorted thank God
