LIMITED TO DAYLIGHT HOURS
Please could someone help me i have jap import 1990 300zx n/a manual and the head lights are not well at all.
when you turn them on in any position they light up the just brightest beam. i have changed the relay under the bonnet and cleaned all the switches, the front fogs dont work either, its starting to piss me off now cos i cant use the car at night so help me please.
many thanx in advance.
The main beams are shite anyway, you could prob get away using them.
Anyway, it's not such a bad thing not being able to use it at night. That means you don't get the twats in their peddle power motors trying to race you.
This really is now my major complaint in life, apart from that cock teasing married woman...
good fun but sadly im nowhere closer to working lights its also mot requirement!
what about checking the earth points at the bulb connections? I'm sure I remember someone saying they had a problem there. The best thing is to get a multimeter and start checking where you have voltages.
Good luck
Vijay
Vijay ive had a monkey electrition out to sort it but no. anyway he took out the relay showed me that the other lights worked when you did something with his curcit tester he said get a wiring diagram for the car i said where from? do you know the where abouts of the earths are located?
thax in advance
I forgot about that little piece of paper.
The bulbs for the driving lights are a bitch to get. I got some from Lucas (456 12v65w H3C Hal is what is on the box)
I believe someone here can convert Halford's ones.
falkirkfan i would be greatfull if you could tell me how to do the conversion on the foggers or point me to someone who can.
The drop down on the logo, its in the tech stuff, then handy hints.
The backs are a pain too. It seems the back lights, the bulbs filaments on the import are the different way around. This means the rear fogs/brakelights(i can't remember) are on when the lights are on.
