Help Harves camber kit
Attempted to fit these today and gave up!!!
Can anyone who has fitted them tell me if the 2 bolts that you take out and replace with longer ones will come apart from the bracket on the inside of the engine bay or are they welded to the bolts?
Cheers,
Andy
Cheers,
Andy
the studs will become loose in the engine bay after you loosen them. the drivers side can be a pita tho as there is stuff in the way.
Cheers buddy,
Did yours come off one at a time or joined by a metal strip?
Andy
Cheers buddy,
Andy
they are joined together by a metal strip its more of a bracket then studs.
they are two different sizes for top and bottom
and dont shear one of the studs :x:
actually mate it was the threads that fooked up on martyns z. took me ages with martyns dremmel to cut the ******* off!! repaced easy enough tho. thats how i know what they are. bloody expensive for what they are too.
