What gauges?
I know a lot of you on here have extra gauges in your cars, I have room for three. I was thinking water temp, turbo boost and volts, what do you have and which gauge would be more useful instead of. :D
Paul
I have water temp, oil pressure and and oil temp gauges fitted in an A-pillar pod.
No need for boost as it's an NA :D :nana2:
I think the 'norm' is Boost, Water te,p and oil pressure, only cos the standard gauges are crap, and you need to keep an eye on these, other wise why would nissasn have put them in in the first place?? :nelson:
Neil
Neil
Good point, cheers Neil
I'm just in process of fitting mine now, they've only been sitting in the cupboard for about 3 years! Got 5 to fit but might have a spare oil pressure one in 52mm if you interested. Decided not to use that one as my stock one seems to work fine so couldn't see the point. Now I only have boost, water temp, oil temp, volts & mixture.
