Need help to identify this [urgent]
ok so i finished to rebuilt my engine and i installed it back yesterday and today.
I installed many aftermarket parts, including a greddy td05/16G turbo kit :)
I've just one concern about this part (represented by the red E on the picture)
So can i remove this? My car is for racing only.
Also, can i by pass it and connect C and D together?
Or can any one tell me where A and B are suppose to be connect?
Thank you for the help :)
PRVR Solenoid, it adds more fuel for the first 30secs to aid hot starting I believe. Totally unneccessary.
Loop C - D (if you dont its dangerous)
Follow and blank off A.
Follow B and remove the tank in the wing.
thank you buddy,
the problem is that i can't follow A and B because they were already removed from the car so i don't know where they are suppose to go !
I already removed PRVR, carbon canister, AIV, EGR... so maybe they were going somewhere corresponding to this one.
tank you, i will loop C and D :D
If I recall the vac lines are from the fuel pressure regulator circuit as ollliezx said just loop em together
