A few weeks ago the horn started beeping by itself when the car was on the driveway, it went on for about 3mins then stopped then 1min later went off again, fixed the problem by disconnecting the battery, when the battery was connected again (about a week later) the problem disappeared.
Just got home today and its doing it again, this time its continuous, disconnected the battery, every time i put the +ive back on it beeps. What can i do?
I very rarly use the horn, a hand gesture seems to do the trick better, where abouts is the wire to disconnect it?
Thanx
Nathan
tell your missis to stop pressing it and come inside !
if you look under the nose panel you will see the horns. just pull the wires off until you find the prob.
ive just taken the fuse out, nice and easy to put back in once ive found what the problem is.
Horns a surposed to bleep :slap: :D Chuck em and get some big fook off truck air horns like me.My stock were a bluddy embarrasment.
I had this exact same problem, and you want to know what it was? The wire had dropped out of one of the horns down by the intercooler and was earthing causing it to beep. Give it a check tomorrow matey
