***urgent Help Needed***
Ok straight to it, if you stand in front of the zed with the bonnet open. in the top metal water pipe that goes into the engine in the centre there are 2 senders in the top of this pipe.
The smaller black one what is it for? it appears to have a spade connection coming off the top and this is broken have managed to wedge it in place but it is in danger of snapping all the way through.
Has anyone got one of these they could get to me as soon as possible (in post for tomorrow or if local can collect.)
or is it a part i can get from a local car spares place and if so what is it and what is the thread..
PLEASE HELP IF YOU CAN dont want anything wrong with the car got the Candy Tunnel run coming up fast and all needs to be spot on..
cheers in advance
cheers in advance
The black connector is for the stock water temp gauge in the dash. You can happily run the car with it disconnected - it just won't show on the dash. Got a replacement one from MJP but is a common part on a lot of Nissans so perhaps try your local dealer or even a scrappy.
Dan
cheers fellas, all sorted now panic over.... just unplugged it as i use my aftermarket gauge anyway, didnt realise it was just for the gauge.. duh!!
tunnel run pmsl mycar is still stalling and has a knackered clutch but sod it ill be there, even if its in a cloud of smoke!!!
sorted now!! lol
saz you can lay a smokescreen so the lambos can see us james bond style..lol
