AVCR Settings
I'm having my apexi avcr installed and setup on Sunday if all goes to plan.
My question is...what settings do I program in and how much boost do I run?
The car in question is a 1992 JDM Nissan 300zx TT manual swb slicktop. It's only done 50k miles and had a full cambelt change recently etc. The car is going to have an oil and oil filter change tomorrow to some silkolene 10w50 i think is in my garage...
The car has the following mods/parts replaced:
Bilstein suspension
SPL type adjustable upper camber arms
Adjustable lower tension rods
New propshaft centre bearing
Trust induction kit
Blitz Access Computer (ECU)
Kakimoto cat-back twin system
Remote oil filter
OE water pump & by-pass hoses
NGK platinum spark plugs
Full cambelt service
The car has recently been checked out by zedworld and has been linked upto the consult and is running spot on.
Any advice?
So basically just trial and error after setting it to that basic setting?
My ecu was already installed on the car when I purchased it as the car is an import. I suspect the ecu map will cater for jap fuel then.
What kinda boost should I be running? 14-15psi on v-power?
