:confused: Im crap at electronics
Right, my amp and subs arnt working, spoke to madhamster at the weekend and he told me to get a volt meter and test the 2 wires that are loose to see which one has the power. simple.
Ive got a volt meter, but what settings do i set it to? Ive got DC V, AC V, DC mA or ohms,
also where do i put the red and black leads?
Thanx
You want DC Volts, put the black test lead down to earth on a bolt/hinge etc and the red one to the wire your testing.
Baz
You need to set it to DC V.
Then the black lead goes to the body work as an earth and the red goes to the wire you are testing. You will get a voltage signal if it is live.
Hope this helps
Darrell
Blimey that must be the most replies in a minute ever.
Darrell
thats what i just thought, cheers guys
