Head removal
I'm in the process of replacing the headgaskets, but just can't seem to get the head off i've undone the 8 headbolts, but the head won't budge? there are 2 what seem to be bolts inbetween the 2 cams do these need to be removed? or is it something else i'm missing?
cheers
carl
8 bolts and it comes off.
Its on two dowels as well.
Give it a little tap with a drift one end, probably just stuck on the gaskets, mine was.
there is also a small 10mm bolt on the back of the head have a look bud
Yup, forgot about those, drivers side its at the back, pass side its at the front. 10mm head
Let's hope nutter is not in there beating the crap out of his head trying to get it off - when he still has some bolts to take off!
managed to get it off with an old part of a roll cage, just need to find time to put it back together now so i can finally drive the thing after i brought it in December
:rofl:
