optima battery!
hi guys!
i cant decide wether to buy optima yellow top or red top? :confused:
my zed is a weekrnd toy so is often sat for a few weeks, i also have high power sound system that i would sometimes like to have running with car off without going flat!
i have red top already which i was told was better for my situation but optima web-site says the opposite???
any help gratefully recieved!
regards steven
Ello bud .. if you have a high powered audio system i wouldnt use 1 battery id suggest an external alternator regulator split charged onto a 2nd battery for audio purposes only the reason behind external alternator regulators is that an alternator alone wont fully charge your battery .. it will charge it to 70% max this is useless as u will be putting to much cyclic duty on the battery ... hope this helps
J
I've run yellow tops for over ten years and nevr had any problems with them.
But it's always good to go with two and a good quality split charger is a must. In the early days I just ran them on a relay switch but it will pop out the fueses if you work it hard.
Chris...
could you explain more, i'm having battery problems which i think may be related
J
[sIGPIC][/sIGPIC]
