gauge upgrade advice
ive just instaled:- ecu chip
exhaust
induction
uprated turbo's
+i'm wating for a boost controller.
ive already ordered a autometer boost gauge
what gauges would you install?????
Jason you know the stock oil gauge is shite???
[This message has been edited by MAC 1 (edited 21-05-2002).]
Dont know if you know this, but the oil gauge that comes from stock, well, its shite!
would u use 2 boost gauges,
what about water temp?
was gonna get oil anyway!
oil pressure is only as good as the sensor it uses.
Air fuel guage is the one to have, and mabey exhaust gas temperature.
[This message has been edited by 300z (edited 21-05-2002).]
OK then lets have a little competition biggrin.gif If you fit an oil pressure guage what should it read? There is no point in having a gauge if you don't know how to read it wink.gif If its just a gauge for the sake of having a gauge then get a voltmeter....
CheerZ,
Andy
PPS It also depends where you mount the pickup feed for the oil pressure sensor as to what kind of reading you get
PPPS A/F guage is probably more use to be honest - at least this will give you a damn good idea of how the fuelling is on each bank of the engine (helping with diagnostics on rough running)
Log onto Tech info for the latest tech info :D
Originally posted by andyduff:
OK If its just a gauge for the sake of having a gauge then get a voltmeter.
Total bollocks,the most important guage to have is the new Blitz rust gauge,It lets you know just how much corrosion is going on biggrin.gif
come-on then andy what should the correct oil reading be?
i was told at idle 28+ is correct pressure.
anything below should be checked out by a garage. jay
jay
TTnet has probably gone down,sure he will come back with the answer when it's back on biggrin.gif.
