- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
Hi guys, just a quick hello from Australia..:) I lurk around here from time to time but my home forum is http://www.aus300zx.com...
Anyway, I'm after some peoples views on a problem I am having, one that I think is linked to the EGR. Having read a few 300zx forums over the years, it seems quite common to remove the EGR when the engine is out. It cleans up the engine bay and avoids some nasty problems if its not working properley. However, this recommendation seems to always be for TT's, but being an NA owner myself I'm starting to believe that the EGR removal is not a wise move for the NA. I want some of you tech guys to tell me if i'm wrong or right.
Now, my car suffers from light / part throttle detonation on hot days and having the aircon on. I can easily accelerate through it, and there is no detonation at WOT, even on a 40 degree day as proved on a dyno. It has already cost me one motor a few years back (cylinder 6 dropped down to 100psi and was burning oil) and unfortuneatly the nasty ping gremlin has also carried over onto my 2nd motor. The only link between the 2 motors is that in both occasions, the motors have run without an EGR as it was removed many years ago. Over the years, I have replaced all (and I mean all) my engine sensors, fuel pump, injectors, fuel regulator, dampner, checked fuel pressure, CAS, MAF, played with timing, ran with colder plugs.... etc etc.... everything you could possibly do to counter act pinging.... but on really hot days, the pinging remains... The only way I have been able to deal with it is to retard the timing a little, and also have an aftermarket piggy back computer installed (UniChip) with which I can take out some timing in the light throttle area's...
So after all this, I regret having removed my EGR which was removed when I had my Headers / Exractors installed which did not have a fitting for the EGR plumbing. And since then, all the plumbing and solenoids have been removed so trying to put the system back in would be a nightmare. My theory is that since the NA runs a higher compression ratio under cruise conditions (10:1 compared to 8:1 on a TT off boost), the high ambient temps make the NA more prone to detonation under these light throttle conditions where the timing is quite advanced (around 35-40 degree's on my manual NA), and the A/F ratio is lean as the O2 sensors try to maintain a 14:1 A/F ratio... Its at these light throttle conditions where the EGR is active and uses inert exhaust gases to cool down the cumbustion chambers..
So is my theory totally incorrect, or just so plain obvious that this post is a waste of time?? If so, then perhaps we should be careful with advice such as removing the EGR as although it may be fine for the TT, it may be detrimental for the NA.
