injectors and wiring
recently had an engine swop, was running fine then began to misfire. wiggled connectors about and found cylinder no4 injector connection abit crap. does anyone supply new connectors?. it happens on and off. sometimes messing with connector doesnt fix it. think it may be the wiring :confused: are there some simple checks to pin point problem.
It's usually a build up of green gunge in the connector so try cleaning them.
Failing that you can buy the connectors with a length of wire and solder them on.
I'm sure MJP will be able to supply them in the traders section here ;)
