protoj · 14 hours ago 14 hr
Hello all,
I have just tryed to do a diognostic test on my 91 uk spec tt I went through the sequence a few times but nothing happends? no lights no nothing? where and when should the lights flash?
Just also done an ECU test and that came back code 55 which is fine.
can anyone tell me why this does not work? and where the lights would flash??
Cheers in advance!!
