I have just fitted blitz bov's in place of my old re-circs and everything was going fine but the drivers side has started to whistle??? i have checked all the connections and cant see whether its the turbo or the dump valve and i am at a loss as to what it could be ? Any coments or help would be really appriciated. thanks
could be that you havent tightened everything up and air is leaving through a tight gap causing a whistling sound.
But this is coming from someone with very limited knowledge
Sounds like air leaking from somewhere, does the car's performance or boost pressure seem to have changed?
Sorry guys couldnt connect to forum ???
I think your right it must be a small air leak, i havent noticed any drop in performance.
i just hope im not doin any damage to the car.
thanks for your help guys
mabey its just happy........
