1faulty elec window advice
this was covered recently but i cant find the post. I had the front windows out recently to get tinted, and they worked when they were put back in as you have to line the windows up to make sure they fit back correctly. but ive noticed now that the front passenger side window doesnt open. Ive not heard a clicking, but that may be down to the bass in the car but the window wont open using either the passenger or drivers side button, yet the drivers side is fine. any solutions?
Hi there Baba-Jan
Had the same problem with mine a few weeks back. For some reason the passenger side window stopped working. It would not work from either switch, yet the drivers side window was still working. I turned out to be a dodgy relay. Sorted that out and it works fine. Could be this M8. Easy enough to fix and would be the first thing to look at before you start taking off door panels.
Good Luck
Simon H
You've checked that the passenger side window is not "locked" using the switch on the drivers door havent you?
Trev
1990 300ZX TT 2+2(import)
http://www.300zx.co.uk/rides/trey/
