My Boot Seems Loose
Although it shuts water tight there is a at least 3mm play in the boot lid when its shut. I'm sure this can't be right. Do i just need to tighten up an adjustment on the boot latch???
The rear boot catch is adjustable so you can take up the play. Alot of the time the bolts are stripped though so it won't stay where you adjust it to. This isn't always the case though and its only a 5 minute job to do :)
yep those bolts are shite, and on mine at least, when you undo them, it always sparks and gives me a good strong electric shock.
