URGENT HELP please!!!!!!
HELP i have just installed the tension rods and upper link arms on my z
final tightening of the tension rod bolts to the lower arm
spec said 80-94 foot pounds so on the safe side i did it at 80
one bolt tightened the other has just spun!!!!!!! threaded which means i cant tighten or untighten.
they were brand new never used powertrix adjustables which i purchased off of yampiedog.
what the fook can i do now!!!!
you will probably have to get a nut splitter (easy to use)... form machine mart etc, or grind it off. then get a new nut and bolt
they are pressed in studs i wouldnt know where to get them. this shouldnt of happened on a new tension rod with under the specified torque!
this has really pissed me off . my only transport and was the last job of the night then it was the test drive!!!!!!!!!!!!!!!!!!!
have to split the nut then and re-fit your old stuff and send it back
or if you want it for tonight then grind it off and be fooking careful...
feel for you fella! stuff like that really grinds my gears :mad:
:shock: thanks for your help mate. unfortunatly i dont think i have that option! my original ones are fubar
can you re-use one of your captive bolts and nuts of your old one on the new kit?
just been talking to pete and we have come to the same conclusion. got to get the old one off. i wonder if local nissan would have them in stock!
:confused:
i said, ring pete he'll know but you'd added an extra post since i'd written it saing you had lol
smithy is on the case for me too. thanks for all your help guys :duffer: :bow: :bow: :bow:
sorted it!!!
i managed to some how with a bit of brute force and ignorence to get the nut off. it hasn't damaged the stud so i reused the original nissan nuts
the pics show the thread of the nut left on the stub, the nut with no thread and the thread of the nut sat next to the nut. ouch!!!
thanks again to all for your help and advice. saves me a walk to work in the morning!
