Skylines
Is there an R36 as i didn't think there was.
Also does anyone have a list of all the engines such as ours is a 32vdett or whatever it is lol :x:
Membership No 0780
INSURANCE GOOFA
the current skyline is a G35, which is uses the same renault lump from the 350z. Im not sure what the next GTR's chassis name is going to be as its no longer going to be a skyline........ time will tell
I think it will be an infinti G35 and the gtr will be a brand on its own.Just badged GTR i think there dropping the skyline name.
thanks guys.
does anyone know all the engine numbers/codes or whatever they are???
Membership No 0780
INSURANCE GOOFA
There was a g35 3.5 v6 going round the time attack track at donnington last september and i thought it sounded pretty nice :)
right engine codes for the skylines.
RB series of engine which is a straight 6.
2.0 sohc (as fitted to the one of the r33 varients) not sure of is engine code, this engine is a bit of an anomaly amongst r33's but is worth mentioning as its disteinctly difernet from the 2.0 turbo in the r32 varient of the car.
ok clear as mud so far so,
engines consist of
rb20de and rb20det which are the non turbo and turbo models of the 2 liter twin cam respectively. (t is turbo ) most often found in the r32 model's.
rb25de and rb25det as fitted to the r33 series. there are two varients of r33 a spec 1 and spec 2 normally told apart by there bumpers etc, and there are also spec one and two series engines ..the spec one engine has a ignition amplifier on top of the the head, above cylinder six. on the spec two engine this is missing. to confuse the issue these engines are not always fitted to the respective model of car, ie it is possible to have a spec 2 engine in a spec 1 car.
rb26dett as fitted to the gtr. this is found in r32 r33.
the r34 has the rb26det "neo" varient i beleive which is quite significantly differnt to preceding engine. im not an expert on the neo so ill refrain form saying anthing else.
one point to note is that it is possible to turbo an rb25de, but the oil ways in the block are different and its a big job. not just a case of bolting one on. and all of the above are DOHC 6 cylinder (with possible of exception of the neo)
hope that helps
