RichardS ·
Need advice pelase.
my Zed's started to play up 91TT(import 2+2).
It misfires and chokes know and again. One day it will be fine and another it will play up.
One of the exhaust smells of carbon but not the other.
Any ideas??
Do you think its a spark plug or HT lead problem or something more sinister?
